gone_walkabouts
Hello hello.
I thought I would throw this one out to the friendly Endless-sphere community...to help get some sanity around this !
I have a 20s lipo ebike that I am looking to set up so I can bulk charge in parallel. What I mean be that is to have a parallel connector running off the connection between the battery and controller. This is so I can just plug is the charger without having to break the connection from battery to controller all the time. Reconnecting at 84v is very loud and scares my dog (and me !) !!
So I have actually been able to do this with my old charger a EMC-2000. This worked putting in a parallel adapter between the battery and controller. Plugging in the charger to the parallel connector had the charger kicking off and charging fine.
I have since starting using a new EMC-1000 charger, this works fine when I plug it directly to the battery (normally) however fails to start charging when plugged in via the parallel connection as described above. The parallel connection is fine, I can read 73V out of that. Just does not trip the charger off to start a charge when in parallel.
I have also tries taking out the lead to the controller and just having the battery and charger connected by the top of the Y section of the parallel cable....nothing it does not start which seem strange as they are directly connected.
Interested in anyone thoughts as to what come be going on. Should this work in theory ? it did with the old charger that has since died ! What's going on?
any help appreciated.
