2008 ZAP Solar PK Truck, 6 batteries, 144 AH rating, 72V total nominal voltage.
ZAP Factory Solar Option:
Solar Panel Rating (Factory)= 180W
Panel Dimensions 34†x 47â€Â
Panel Area = 1600 Square Inches = .63 square meters
VEHICLE ENERGY USAGE:
Energy Usage to drive 8 miles of city driving, stop and go with 30 traffic lights and one stop sign, 35 MPH typical speed. Begin with full charge, then measure recharge back to full using Kill-O-Watt meter in 115V AC outlet:
8 miles recharge = 3.0 KWH
SOLAR PERFORMANCE:
Latitude, Longitude = San Jose California
Date = 3-29-2009
Time = 2 PM
Conditions = Sunny. No Clouds. Light Haze.
Solar Open Circuit Voltage = 136.7V Panel Normal Incidence angle to sun
Solar Open Circuit Voltage = 136.0V Panel Horizontal
Solar Panel connected to battery pack:
Battery Pack Voltage = 81.2V
Solar current = 1.21A
Solar Watts = 98W
Solar Panel Horizontal to ground
Solar current = 1.12A
Solar Watts = 91W
Add small 12V Gel SLA battery to pack to simulate common ZAP upgrade to 7 batteries, 84V nominal voltage:
Battery Pack Voltage = 96V
Solar current = 1.20 A
Solar Watts = 115W
Solar current = 1.08A
Solar Watts = 104W
Conclusions:
-Solar Panel does not meet rated 180W spec, but will get closer in the summer months.
-Adding a 7th battery will help extract about 10% more energy from the solar panel.
-Daily solar energy contribution unknown, but probably about .8 KWH, which will give about 2 miles of driving range based on 3 KWH = 8 miles.
-A benefit may exist from a continuous solar trickle charge being able to reduce sulfation-related battery pack degradation.
-The solar panel option is costly, so the above observations may not justify the cost for most people. My main reason for opting for the solar option was as a hobby, or for fun.
SOLAR PERFORMANCE:
Date = 3-29-2009
Time = 2 PM
Solar Watts = 98W
Solar Watts = 91W
Solar Watts = 115W
Solar Watts = 104W
Conclusions:
