ElectricGod
Quick report on the ASI BAC 2000 vs the PV 12 fet controller...
I set the BAC2000 to the same settings as the PV 12 fet. I got an extra 1 mph with no field weakening than the PV with no field weakening. The controller overheated after about 30 minutes of use and then went into a low power mode until it cooled down. I never had that problem with the PV controller. The BAC2000 was HOT and the air temps were in the 60's F. Go figure! It ran my C80100 just fine, but I can't say it was transcendentally better that the PV controller. The one thing I can say as a positive thing about this experiment is that current draw was lower. At WOT, the PV controller will pull about 60 amps. The ASI pulled around 50 amps with similar acceleration and speeds. That was fairly compelling!
