Svooper
Oh did not see that, thanks anyway for the infoI believe my 10:56 AM comment above may be applicable.
Here you have some pictures of the projectYou have go-kart motor and planning to install it on a bike? It doesn't make any sense to me. There are so many ready made hub and mid drive motors ready to install on a bike.
Can you post some pictures of this project of yours?
What do you guys think of this battery?
Yeah its a quite big battery but as i said, do you think its high enough quality to not cath on fire and will it be enough for the motor.a) Did you check dimensions?
b) In my humble opinion you should pause for a moment and have a rethink. This project of yours loos like a death trap.
And i assure you, the project is completely safe
It is an aluminium frame and yes, all the holes you see are drilled.I hope that is a steel frame, but it looks like aluminum. All those holes drilled in the rear chain stays look like likely failure points to me.
Two drilled holes and a steel frame on the other side with two holes for the other screws.How did you mount motor to the frame? Two drilled holes?
Periodically inspect the drilled holes that are being used to mount the motor, so you can find cracks before they sever the frame tubing.Two drilled holes and a steel frame on the other side with two holes for the other screws.
Btw i have been working on this bike for 6 months with 1 earlier failed attempt using a hoverboard motor.
Okay will keep that in mind. But for the time i have used the bike now I cant see any visible damagePeriodically inspect the drilled holes that are being used to mount the motor, so you can find cracks before they sever the frame tubing.
Bicycle frames generally don't have a great surplus of structural material to help them tolerate drilled holes.
It might be okay indefinitely. But keep an eye on it anyway.Okay will keep that in mind. But for the time i have used the bike now I cant see any visible damage
I have been working on this for so long because the first attempt was just a fun side project. The first attempt tok months because we had to figure out how to contorl the hoverboard motor. After it failed we put it on ice for several months beofre ordering this new motor, all the shipping time will probably add up to three weeks if even that. Installing this motor only took 3 days of work plus some designing a way to attatch the gear to the wheel. Here we are today trying to find a good battery.Can you help me understand why?
I have a feeling like you are inventing an ebike in 1960 and you jumped here to ask some questions before coming back. There are so many ways this project might go wrong. I won't even mention Swedish road police. Why would you risk your own life?
You can buy hub motor, KT controller and battery for little more than $300, and it is a few hour job, so why would you put all this effort into creating a deathtrap?
PS Are your brakes in working condition? It might be a poor picture quality, but I don't see brake pads there.
If it helps, normally you don't have to do that--you just squeeze the arms at the top and pull the noodle out of the top of the arm it hooks into, and then the arms spread apart far enough to easily get the tire past them.The brakes are in working condition and the reason you dont see brake pads is bacsue i had to remove them to remove the wheel.
That's a woefully uninformed opinion you have there. Rim brakes aren't necessarily weak or unreliable, just like disc brakes aren't necessarily strong or reliable.1.8kW and rim brakes? Oh dear... what possibly could go wrong?
Yeah, the battery worked perfectly and our Ebike works great . Its top speed is 47kmh on flat ground and the battery lasts for more than an hour of average biking before running out.Any updates on your project?
Is this the friend or the OP? Why not stick with one username to make it more clear who is posting?Yeah, the battery worked perfectly and our Ebike works great . Its top speed is 47kmh on flat ground and the battery lasts for more than an hour of average biking before running out.
