I hate to break up this wonderful banter, but, I have some motor info to share........... :wink:
The cans should be at Astro any day now (we could not find decent keyway 1/2 inch shaft, so we machined our own).
In the meantime, Bob setup a 3 inch stack 3220 (the same internal structure as this motor) and did some dyno-endurance testing. He ran one at 5,500 watts for 10 minutes wrapped in insulation (no cooling what-so-ever) as a thermal test. After 10 minutes, the windings started to smell, but it still was running. He said it takes 60 seconds for the core temp to reach the outside of the can. So, he is doing some calculations of what the motor can take based on that. Also, once he has our finned cans in hand, he will dyno test these for 10 second, 60 second, 5 minutes, and 10 minutes at various wattages to get a true rating for each. However, the preliminary numbers look VERY good. The 14kw number should be fine for our usage. He said his only concern may be using these motors at that ouput for extended periods without active cooling. However, in the ebike, or dirtbike applications where power is consumed in short bursts of a few seconds with a few seconds rest, the output should be through the roof, far over 14kw.
Also, he tested the motor up to 27,000 rpm without any problems. So, we know it is durable.
Matt
