fractal said:
I looked at your pics! Good job on those dropouts!!!! being removable, it looks so much easier to work with (I think). Instead of making a new dropout like you did, do you think it would be possible just to modify the axle hole and then adding a torque arm???(I dont have access to a CNC machine
cheers mate! Im kinda surprised they worked out as tidy and close fitting as they did. took quite a few hours with a grinder and file to get the 3 bolt section that attaches them to the bike all nice and rounded.
I only had access to a mill and a drillpress, a cnc would have made it soooo much easier! But really I could have managed just with the drill press and a angle grinder.
If your thinking of doc'bass's torque arms then yea, should be fine I think. I'd be tempted to get them welded to the dropouts professionally rather than rely on the glue that doc reccomends, particually seeing your modifying the dropouts too. keep in mind though, Im a sucker for over-engineering stuff, so generally what I do ends up being one or all of - expensive/heavy/timeconsuming/PITA to get right/way too strong.
My only worry would be that when you cut the slot into the current rear of your bike its going to weaken that area a fair bit (enclosed > strength > open dropout). Adding torque arms would more than make up for this, but only while they stay attached. glue might deteriate and fail eventually. A good welding job wont (or, is less likely too :wink: ). Just be aware that your frame is probably aluminium, and the dropouts are steel (i think?). Harder to weld. Ask some local shops before deciding witch way to go.
