Skedgy Sky
One rainy day I parked my bike and turned wheel lock on as usual.
I come back 5 hours later, turn wheel lock off and controller blows.
Today I replaced these FETs and did the usual resistance tests for shorts - everything looked fine as far as I could tell.
I plug power to the controller... everything good.
I flip the ignition switch and all the 6 FETs on the phase that I replaced blew again!
Seems FETs blew both times ONLY when controller was powered AND ignition was on.
With controller powered and wheel lock on, FETs did NOT blow.
Why didn't replacing the FETs work? Why is the controller blowing up when ignition switch is on? It was working great for weeks before the first incident.
Edit: Probing around with my multimeter... One of three of the 0 ohm gate driver resistors is not showing any continuity. Is it related to cause of all this?
Edit 2: I put two good FETs in, one on high side (connected to one of the good gate drivers)and one on low. Power to controller - good. Ignition switch turned on - *boom*. Wasn't as bad as if I had put in 6FETs, I suppose.
