1-track-mind said:
SW, thanks. This is a huge help to get this all out on the table. What are your thoughts on dual wheel drive to split up the work between two motors ? From a cost standpoint, I was looking at the Currie/9C combo.
That should reduce the work on a hub motor which may help prevent over-heating. How much the work is reduced, though, depends on the currie motor's characteristics and gearing, how much you're going to pedal along on the hills and what speed you're going to choose to go (More speed = more work from the motor). Since I know nothing of the three, I can't really help much.
I also don't know if the front forks of a currie bike would work without fail with the 9C. I'd have to check the opinions of other currie bike owners. I also don't know if the currie bike's motor could also take long sustained hills.
The easiest way out would be to get a rear 5304 or so on a 20 inch rim, a 48 volts 30 amp controller or 72volts 20 amp controller (depending on battery), and about 1.5 kwh of batteries (Something like 48V 30Ah or 72V20AH). If you run out of juice, though, it's going to be a beast to climb with. I think that would come to about 1500 dollars and it seems 15-18 mph would be realistic.
The cheapest way out would be a 9C motor with cooling mods on a 20 inch rim. Get a 2806 9C motor with a 30 amp controller, and the same amount of batteries mentioned above. With pedaling, you should be able to sustain 15-18 mph. According to the simulator in my signature, in this configuration, the motor can be upto 80% efficient which is about as good as a geared setup would be. The total cost of this setup would be about... $1300?
That kind of bike would have some high torque loading, though, so I'd probably only trust it on a rear configuration. I don't know if 9C motors are offered in a rear configuration.
Here's a 48V30AH pack at ping battery -
http://www.pingbattery.com/servlet/the-17/48V-30AH-V2.5-LiFePO4/Detail
If you're ok with the thought of the battery cutting out a mile or two before you reach your destination and you're going to be pedaling a bit, you could get a lower capacity battery for cheaper.
http://www.pingbattery.com/servlet/the-20/60V-20AH-V2.5-LiFePO4/Detail
Even cheaper would be a 36V30Ah battery, but there's a pretty good chance it will definitely cut out upto 5 miles before you reach your charging destination, pedaling or not.
You can get a cheaper deal with LiPo, but you HAVE to know what you're doing. You could get a cheaper deal on LiFePo4 batteries if you're willing to build it yourself. You'll need to buy a charger and do a lot of work going down this route, but evcomponents.com has the bare cells that you could use. A 60V20Ah pack would require 20*2 = 40 cells and that's about $800. You'll still need a charger and BMS, though, which would probably add upto to nearly the cost of a complete ping battery.
Thundersky batteries might be possible and they're pretty cheap at nearly 50 cents per watt-hour and a 30v40AH pack would cost about $600... but it doesn't seem like there's a lot of experience with those around the forum, and you'd still need to build it and get a charger and BMS.
