Hi,
I have read and searched and come up with a few opinions myself. But since I don't consider myself anything close to an expert in this area was hoping you may indulge me with a recommendation.
I have a 20S 12P pack I'm building from 240 Samsung 25R cells. They are rated at 20A max continuous, 2500 mAh. So if I do my math right I have a 74V 30 Ah 2.2 kWh pack.
I'm using a Power Velocity 18 F controller which is rated at 80A. Motor is a QS205 V3.
As I understand it, the controller will be the limiting factor here correct?
I emailed Lucy at BesTech and she's going to get back to me with a recommendation from their line.
Are there any other BMS I should be considering? I would think bluetooth would be great or some way to limit the voltage so I can charge to 4.1V
I'm a total rookie at this but I'm learning
Thanks
Thanks
