Byte
Oooh I hope so that this new ESC will be able to handle a CA120! Would be awesome! Thos rewound and black anodized C80100 look nice too!
Congratulations Bruno!
liveforphysics said:Say its all aluminum core PCBs. Where does the heat go?
I have a video of the latest greatest fighter cat 100v esc (claiming some hundreds of amps number) blowing up after 20seconds of 100amp battery current.
450amps will melt the solder off a pair of 8awg wires in less than a minute. This guy is full of shit.
liveforphysics said:This is a controller rated for 350amps for 2minutes when bolted to a huge 5lbs heatsink.
It's got massive fat high current busses running all over the place.
bearing said:I don't know which heatsink Sevcon is using, so I'm assuming something similar to this 300x300x40mm, which is 0,28K/W (natural convection). This puts the heatsink at 56K above ambient at nominal current, and would put it at 340K above ambient if used continously at 350A.
brunotollot said:Good evening.
I want to just talk briefly about my product and let you know why this product works well and hopefully to demonstrate that I am not "full of shit" as I have been refered to by someone on here.
liveforphysics said:Everyone of us would be ecstatic with 24s 420A. The problem is, it's impossible for that controller to even be close to 150A 24S, but they are claiming it's 420A.
neptronix said:I'm beginning to think that this is worse than the "ultrafire 4000mah" battery thread.
brunotollot said:This discussion is going on too long and maybe my English is not correct so I could not explain everything right.
neptronix said:I will be disappointed if i do not see a video featuring smoke billowing out of this poor little thing by the end of the night.
I would limit it to around 25 amps to start!gwhy! said:LFP.. please be gentle with it, at least give it a fighting chance.. Do these controllers have current limiting ? if so is it adjustable ( please limit the max current initailly to 100A and step up in increments of 10-20A at a time , if possible to do so ). I understand that this one do not have sensor inputs, When can we see one with the sensor inputs ?.
Arlo1 said:I would limit it to around 25 amps to start!gwhy! said:LFP.. please be gentle with it, at least give it a fighting chance.. Do these controllers have current limiting ? if so is it adjustable ( please limit the max current initailly to 100A and step up in increments of 10-20A at a time , if possible to do so ). I understand that this one do not have sensor inputs, When can we see one with the sensor inputs ?.
Yup I would Start with a motor with >100uH and 25 battery amps for 1 minute and watch the temps amongh other things.liveforphysics said:Arlo1 said:I would limit it to around 25 amps to start!gwhy! said:LFP.. please be gentle with it, at least give it a fighting chance.. Do these controllers have current limiting ? if so is it adjustable ( please limit the max current initailly to 100A and step up in increments of 10-20A at a time , if possible to do so ). I understand that this one do not have sensor inputs, When can we see one with the sensor inputs ?.
It's pretty big, I bet it could realistically do at least 40-50amps for a true continuous duty cycle.
As far as the motor to test it with, I've got pretty much everything available. I was planning on using something that has a controller friendly inductance so we can get good testing out of it before something pops, but there certainly is value in seeing if it's able to handle some of the less friendly RC motors as well (which would mean I have to make mounts to bolt them to the dyno). What do you guys think?
It would be good to know what it can do on a tame motor like a hub motor. In fact no one has ever tried a rc controller on a Hub motor as far as I know and I think they could be ok on a hub motor.fizzit said:I say duct tape a good ol' turnigy 80-100 to the dyno and hook this baby up! There is no reason to waste time on motors that any controller can drive
I stand corrected and I now know.hydro-one said:yes yes yes yes
re" rc controller hub motor JRH has been doing that for ages!!
And if THAT works. . .fizzit said:I say duct tape a good ol' turnigy 80-100 to the dyno and hook this baby up! There is no reason to waste time on motors that any controller can drive
Arlo1 said:Nonetheless you will most likely find it can run harder on a hubby then a RC motor.
Byte said:I cannot wait to see results of this thing!
