Sr.Agaporni
I got a controller from EM3EV with 6 fet 4110 (specs). I am planning to use it with a 90V (82V nominal) battery limited at 20amps with a Cycle Analyst. It should work as those are the limit specs, but, any experience with that controller at those limits? Do you think it will work without problems or will meld or something?
My second option is the same scenario with the 12 fet 4110 at 90v 30a, but I am having problems with the controller and the Cycle Analyst at the moment, so not sure if I will be able to use this one.
