Hello,
Optional intro
I'm starting a new build soon (electric kickbike). I would like the option to limit the top speed to keep it road legal (27kmph, 17mph). My controller needs the optional display to do this, but I would like to keep the setup clean/simple and not use the display. If I understand correctly the throttle is actually a potentiometer, so a kind of variable resistor to send a voltage of 0-5V for a 0 to 100% throttle control. I understand that I would need to experiment with different resistors to get the speed correctly.
Actual question
Can I limit the top speed by adding a small resistor between throttle and controller?
For example
Stock: 0-100% throttle = 0-5V output
Add resistor: 0-100% throttle = 0-4V output, so limit to 80% throttle
It would then be easy to create a switch of some sort to go from 80 to 100%.
thanks for confirmation
Optional intro
Actual question
For example
