joshseitz
I've decided to shelve a new build for this year, so I am looking for ways to squeeze more fun out of my existing ride [Cannondale Bad Boy, Amped (MXUS?) front geared motor, compact 13A controller, Ping 48V 20Ah LiFe battery].
The Ping was more or less rebuilt last year (thanks again for your help, dnmun), replacing a number of pouches and the BMS). It is still performing well, but I would like to add a little more "punch" and top-end.
I was thinking of adding a 2S or 3S LiPo pack (8000mAh or so) to get me closer to 60V territory. Charging would be handled independently using my RC charger.
My first question: in what order should the LiPo booster pack be added in series? Behind or ahead of the Ping
Additionnaly, since these packs are of dissimilar capacity (8Ah vs 20Ah), what exactly would take place if I deplete the LiPo booster pack, leaving 12Ah of capacity in the Ping (assuming they discharge at the same rate?).
Finally, will my little Amped controller handle the added voltage of the booster pack? Not too worried if it kills it - I wouldn't mind moving to a 20A controller (then I have to worry more about killing the little Amped front geared hub motor!).
