mattjrogers
- Joined
- Apr 15, 2017
- Messages
- 10
I have a 48v 16s1p 45Ah LiFePo4 prismatic battery with what looks to be one weak cell that drains faster than the rest. Simple question - can I add a single parallel cell to the weak one to increase its capacity and allow the rest of the pack to continue working without tripping the BMS low voltage cell cutoff? For example, adding a 10Ah cell to the weak one in parallel to give it the extra capacity to work like the rest. This would save having to purchase a more expensive larger cell as a replacement.
These are generic cells from china. Supposed to be 45ah, but have yet to fully test the capacity and they could be 40ah. I did just run the pack down 35Ah and found the one cell at 2.40v with the rest at around 3.00v. This was immediately after the ride and obviously the voltage was slowly rising, so I don't know what voltages the cells would have settled at as I put on the charger after the ride. My gauges read that the minimum voltage drop was 42v on the pack under full load at the end of the run, but the overall pack voltage under no load was around 48v. What is the currently accepted minimum cell or pack voltage for prismatic LiFePo4 to set the BMS low voltage cuttoff for the battery?
Anyone know where to get a 45ah prismatic cell?
If I can't find an exact match, would the new cell possibly be not well matched with the pack by being too high capacity if it is better quality? What would you do if you had to replace a single cell if you could not find a perfect match and had to guess on what to purchase? Batteryspace has a 40ah single cell that could be a match. electriccarparts.com has 20ah cells that could be paralleled to match.
Right now I have a BMS that is hooked up as a charge-only-bms. I am getting a new BMS from Aliexpress BMS with bluetooth connection that I can monitor during riding and charging on my phone. It was $58 and allows me to program all values and see individual cell voltages on an app.
https://www.aliexpress.com/item/16S-50A-LiFePO4-BMS-PCM-PCB-battery-protection-board-for-16-cells-18650-Battery-electric-car/32807567276.html?spm=2114.13010608.0.0.EsK98k
