I want to add power to my normal mtb so I can get to the trails without spending too much energy on the road. I don't need a lot of power, even 300w peak/200w continuous would be enough.
My restrictions are:
- low budget - I don't want to put much money into this.
- convenience - I don't want to spend 5 or 10 minutes swapping out a hub wheel when I get to the trail
- mtb has knobby tires - so friction drive won't work
- mtb needs to not have any e-components left on it (other than a throttle and a wire) for when I hit the trails
I built a pusher with a 26" hub wheel. Built my own 2 axis hinge that attached to my seatpost, but it's still too unstable.
Using a small hub wheel would help, but I think I need to get the attachment arm down near my rear axle to get the weight lower. I've seen the Weezee, but that would mean spending money on a tiny hub wheel.
To make the joint simpler, I am thinking of doing a two wheeled pusher, so it can balance on it's own. Just add an arm with a 12" kid wheel to the other side of the hub drive wheel. That would work just like my instep cargo trailer.
As I said above, the most important thing is low cost and disconnect in under 30 seconds.
