Motor - for now it's a 500W hub with a 10 inch tire. The plan for the future is to upgrade to whatever motor I need for my goal.
Battery - for now it's an 18S20P made of Konions, 66.6V and 30Ah. The plan for the future is to upgrade to 14S36P of Tesla cells, 51.8V and 108Ah. I would like to go back to a 48V system capable of a lot of amps.
Terrain - mostly flat with the occasional 3 to 5 degree hills, not long ones, half a kilometer at the most.
Rider weight - 255 pounds
Scooter weight - 225 pounds with present battery.
Weather - 70s to 90s in the Summer, 10 to 0 in the Winter. I ride in the sun, the rain, the slush, the ice and snow.
Space - I have a good amount of room on the side of the scooter under the side skirts. I had a Lyen 18fet with a DC/DC converter with all the wiring and fuses for the power system and 12V system under one skirt with a little room to spare. I can put a significantly larger controller under the other skirt where there's presently nothing.
Cooling - plenty of cooling under the skirt. It is possible to bolt a thick aluminum plate to the chassis to secure the controller on and serve as extra heat sink.
If the new controller is programmable and I can limit the amps and speed then I was thinking I can run the motor and battery I have now until I upgrade both.
Thanks
Ray
