d8veh said:
I think that a more likely explanation to your problem is due to sub-standard replacement gears. Just bcause they look the same, it doesn't mean that they're made of he same as the originals. I'm sure Bafang are now using a special high strength polymer with a lot og glass reinforcement, while as the replacements might be plain Delrin or something similar. My neighbour's been running a 250w SWX with 22 amps for two years now. We don't do any serious off-road, but we use plenty of unsurfaced cycle tracks through the woods etc. Your first set lasted for a fair while, and then the replacements failed almost immediately.
Did you check that your ring gear hasn't cracked?
You know, that hadn't occurred to me, but it makes perfect sense as an explanation..... especially since I think I've done another gear today and I REALLY nursed the throttle on every road imperfection. I haven't opened the motor up yet, but I'm pretty certain since I'm hearing that familiar clicking sound. When I do, I'll be sure to check the ring gear too.
I bought my replacement gears from greenbikekit.com and I haven't read of any complaints about them before, but maybe I could have got a bad batch.
As it stands, I think there are two possible solutions to resolve this satisfactorily:
1) Source some metal gears and run either 1 metal and 2 nylon, or 3 metal.
2) Replace the geared motor with a direct drive unit.
Having refined my first build over the past year (you might have read my ghEttoBIKE thread on pedelecs.co.uk), I have reached the point where I am totally happy with the performance of my bike. The reliability issue of my geared motor really is the last remaining problem.
I would really rather prefer the first solution to the second. So many on this forum rave about running metal gears, but not a single person has been able to advise on where to source them from. I have spent hours looking on the interweb, but I just cannot find them in the 36-tooth variety.
I'm getting desperate now as I'm about to use my last spare nylon gear, so I'd really would be appreciative if anyone knows of a source of metal ones.
