I Just updated the Blog on my Site:
There are some new pics as well..
I put some Code on it, now I can use an RFID Tag to activate the bike and switch between street legal and unlocked mode.
I also put a code snippet online that allows to measure the cadence of the PAS (only works with PAS sensors that detect if it spins forwards/backwards)
I dind't ride the bike for long distances so far but the battery is performing pretty well.
Initially the Sabvoton controller was quite a hassle due to the bad documentation but I finally got it running like I want to. Too bad winter has come...
Variable regen works like a charm
If I pull the brake, the throttle acts as a variable brake. (The e brake ph current has to be set to the wanted ph current*10, apparently thats a bug in the software)
The multiple use throttle is only possible if either the acceleration time is set to a high value (like 2000ms) or if the throttle has to be switched to 1V first to make it work again. I chose the high
acceleration value. Initially it feels unnatural but I got used to it quickly.
@emoto
Finally.. I tried the bluetooth module once, but its useless crap xD
The next steps will be: Selfmade cranked seatpost with about 50mm offset (couldnt find it anywhere to buy) and i will try to get it licensed.
And I will also change the throttle....the orange just doesnt fit
