I dont seem to be having much luck with the cyclone CY-650 - 1680w motors as I have had yet another one fail on me. This must be at least the fifth one to fail with hall sensor fault.
The latest one is acting like a heating problem as it will work perfectly ok at night when its cold but will keep cutting out in the day and throwing up a hall sensor error on the kelly controller. It only needs the sun to be shinning on it for a short while and it will refuse to run and just keep cutting in and out.
The previous motor is completly dead and the kelly controller reports a hall sensor error, I have replaced the controller on the off chance it was the controller at fault but it has made no difference with either motor.
I cant afford to keep replacing motors as it's just too expensive at over £200 a time.
I would like to have a go at repairing them, but not too sure if just replacing the hall sensors will be enough. Also I would prefer to put in better quality hall sensors as the originals seem to keep failing.
Is there anyone here that has had experiance at replacing the hall sensors in the cyclone motors that could give some advice and possibly part numbers for a better quality hall sensor.
Scott
Scott
