Any way to verify AH on a battery?
unclejemima
Western Canada
Is there a way to verify AH on a battery purchased from Amazon?
I'm looking at this bad boy...48v 24.5AH!!!! Upgrade from my 48v 11AH unit.
https://www.amazon.ca/gp/product/B08X2F2DC7/ref=ox_sc_act_title_2?smid=A1DQ8CBGDI0TLE&psc=1
I'm not looking to increase speed, rather reliability. So choosing the 48v over the 52v. I'm running an order BBS02 that has had a new controller installed a few years back.
Would love the extra AH the 48v unit provides.
Thanks guys,
Require the seller to provide a picture of the Samsung 35E cells built into a pack before you order. If you're skeptical, require another picture of the cells in your pack before it ships out. This won't prove they're new cells, but it's better than nothing.
As an aside, I'd expect any reliability difference between 48V and 52V to be marginal.
Yes, if you have or get a load device that pulls a constant very low C-rate, traditionally over 20hrs
If strictly constant amps then just use a timer
otherwise put a coulomb counting wattmeter in between, a bit less accurate
Draw down from 100% Full to 0% empty as defined by the battery data sheet.
If you pull faster or stop earlier you might get say 20% below nameplate.
But lots of makers it's impossible to match because their rating is a fantasy
You'd have to buy it, install it, ride it with a watt hour meter attached, and find out the total amp hours after the fact. Not a super precise way to do things, but close enough.
If they lied about the capacity, shipping it back to China would be cost prohibitive and you'd end up ripped off, like many new builders looking to save a buck would.
You'd be much better off spending a bit of extra money with a vendor that actually has a reputation.
Even with the best quality cells and a purely honest vendor
a bank accurately rated at say 40Ah
would only deliver say 30-35Ah in real-life conditions aimed at good lifecycle longevity.
And you can NOT legally ship it back without find a willing shipper that has a "hazardous cargo agreement" with an international common carrier ...
A bank accurately rated at say 40Ah
I've tested plenty of 3000mah 18650s that all came in at or greater than 3000mah.
The issue is that a seller can sell a "40ah" pack for more $$$ than an accurately rated 35ah pack. So they call it a 40ah pack.
Yes I meant finished packs, normal IRL usage
charged to 4.05-4.10Vpc
LVC set at 3.4-3.6V not 2.8Vpc
discharged at maybe hundreds of amps peak, not CC at the 10-20 hour rate
Figure 2 AH per row and if a battery is really small or light it's not going to very powerful as a rule.
Same picture, if you select 13 ah, or 24 ah. So that picture is the 13 ah, for certain sure. If you select 24 ah, you will get a square pack wrapped in cardboard and duct tape. It will be a huge box, with cheap ass cells inside.
The kind that burns your house down. Or at least burned my house.
I use this
https://www.aliexpress.com/item/32866240382.html
to validate the AH of any battery/cell I have,
Very easy to use, just hookup battery to the input side and set the cut off volts to something lower than BMS setting [so you can double check if BMS is working] and set amps and to keep watts below 180w (ish), and wait...
Lot of cheaters selling sub-standard products.
If they are not willing to divulge the details of the cells, then walk.
Charging/discharging - I read that keeping max charge level 90%, makes em last longer and less heat too.
Also, heed what Dogman Dan said about burning the house down, I always charge attended and turn of chargers off if I will be gone for few hours. Just be prudent.
