We are still awaiting the arrival of an e-assit recumbent trike that we ordered for my wife in April. She loved the demo ride but remarked about not getting a very good view in the rear with the mirror. We do much of our riding on busy bike trails and the road bikes especially come up behind you fast and silent, often not using a bell or announcing a pass.
I had some spare parts lying around and was looking for a project to do, so I came up with this homebuilt unit as pictured below. The unit itself will mount on the underside of the rear rack, using velcro to provide some shock protection from bumps while underway. It is 8 inches long, 3 inches wide, and 1 inch thick.
The box contains a rearward facing camera and red rear light powered by a 3 cell lipo battery, running everything should get about 2 1/2 hours of runtime. There is a power distribution board to step down voltage to componemts that require it as well as to filter the video signal. A video transmitter sends a signal on a 5.8 mhz frequency at 25 mw of power to a hi-res 2.5 in. monitor mounted on the steering arm. A major concern is the build-up of heat by the transmitter, to address this I have a fan blowing air over the tx, works well but it generates too much noise for my liking.
I'm going to try using a heat sink on the tx to see if it would suffice in keeping the tx to a reasonable temperature without overheating.
I also need to dial-in the camera settings to get a good image under a variety of lighting conditions. The camera has wide dynamic range and other settings such as brightness and contrast to tweak to your taste.
The box itself was made from 2mm acrylic sheet available from Lowes or H.D. for 4 bucks. The standoffs are used to attach the top of the box and to provide some structural ridgidity.
