dirkdiggler
- Joined
- Oct 17, 2012
- Messages
- 641
Much appreciated as always! I kept reading the PDF from Kelly trying to figure it out. Spent hours searching the web. Came across this post from Luna Cycle's forum on how to hook it up to the Cyclone.
WTF does that even mean? I don't need a key or on/off switch, just want it to run when I plug in the batteries. Just needed some reassurance!
Keep us updated on the 7.5kw motor and curious as to what frame you are getting.
Red (no #, from throttle switch/key): Battery pos (+) out (connects to cyclone motor pcb and thermostat, then loops back to Pink (#7) to power controller
Black 2 Pin (male, wired to 7 pin): Throttle power switch/key (no numbers assigned to wires)
Red (bullet to black 2 pin, power in): Battery pos (+) to throttle switch/key
Red (black 2 pin to black 7 pin, power out): Battery pos (+) to motor, thermo, back to Pink (#7)
