Hi,
I opened up the engine and everything looked nice. No sign of any burning.
Then i dragged out the multimeter and followed this guide:
Use your multimeter in the ohm (resistance) setting. Check the resistance amoung the 3 wires from the motor (in pairs). The ohms should be about the same between any 2 wires. If you have one set with much lower resistance, you have an open coil in the motor. If you have a set with much higher ohm reading, you have a shorted coil (motor should smell burned).
If the motor checks out, do the same on the 3 wires to the ESC. Again, you should get about the same readings between any pair of wires. If you have a much lower ohm reading, one or more FET transistors are open in the ESC. You should never have a short in the ESC without significant circuit damage. That would be obvious.
These are crude tests but they should get you close enough to figuring out if it is the motor or ESC
When checking the motor side everything was fine. When i checked the controller side i couldn't get consistent results. So I lean against that the controller is blown. I also get the same error message when the motor is disconnected, which i guess indicate that the motor isn't the problem. Does it sound correct or could it be something else?
Any other way that i can check the controller?
I tride this guide but couldn't understand what B- is:
circuit wrote:
A faint click on startup attempt sounds like a shorted phase. Most common reson is shorted mosfet, most likely low side. That is easy to check:
1. Take a multimeter and switch it to diode (-<|-) mode.
2. Connect red wire to B-.
3. Connect black wire to each phase. You should see redings around 300-700. If you see something like 002, then you have a blown mosfet. Replace it or bring the unit to electronics workshop to do the job.
4. Repeat steps 2 and 3, but with B+ and switch black with red.
