tomjasz said:http://www.bike-emotion.org/pedelec-motoren/pedelec-tretlager-mittelmotoren/ersatzteile-zubehoer-fuer-bbs01-02/lagerschalen-set-bbs-motoren.phpdusan said:Hello bgt,
Can you please post link where bafang bottom bracket bearings can be ordered from Germany?
Thanks
I found, outside bearing on right side of bottom bracket has small clearance, I will probably replace it.
Bearing number is 16003RS.
I'm wondering if I will need to replace also others.
maybe they are updating the site. I cannot get it either. But it is on Facebook.https://www.facebook.com/bike.emotion.org?fref=photoKarius said:This link is not worktomjasz said:http://www.bike-emotion.org/pedelec-motoren/pedelec-tretlager-mittelmotoren/ersatzteile-zubehoer-fuer-bbs01-02/lagerschalen-set-bbs-motoren.phpdusan said:Hello bgt, Can you please post link where bafang bottom bracket bearings can be ordered from Germany? Thanks I found, outside bearing on right side of bottom bracket has small clearance, I will probably replace it. Bearing number is 16003RS.I'm wondering if I will need to replace also others.
Karius said:Here is my silicone gasket, only run 40 km. I wonder what the Chinese think of when they perform to install a silicone seal between the nuts. When this error shows up repeatedly it should go up a light for those. They are so good at copying others' solutions but to find their own solution, proves to be difficult.
By the way. Can someone tell me how I open the first nut on the left side? I don´t now what type of tool I need to open these nut. Is it a "work around" to open it?
I have exactly the same problem, discovered yesterday after only 30km total tide time. The link below shows complete disassembly. The nut removal is performed using needle-nose pliers. I will be trying this later today.
https://www.youtube.com/watch?v=hfVAa5M6Nmk
tomjasz said:I'm afraid what you see is what we get.
I think inspection and greasing bearings may be a reasonable expectation and maintenance item. Especially on a high mileage daily runner used for commuting, and even more important on a MTB or FTB.
But let's not get this thread confused with the thousands of drives running daily without a glitch. The competition still hasn't matched or exceeded the abilities of this motor.
Did you get a piccy of the seal Chewy?Chewy said:I have just bought a 750w 25a unit direct from china.
After 50 kms the freewheel screws came loose. When disassembly the unit I found it has a real rubber automotive type oil seal sealing the non drive side.
Looks like they have updated the design.
phiz said:After 1500 miles my left thrust bearing turned into dust. Thanks to this excellent thread I was able to replace them with no issues.
I ordered the thrust bearings from http://www.california-ebike.com. They cost $20.70 each (paypal). I also got new needle bearings from http://www.california-ebike.com since it was open and they were $6.90 each. I tapped them out / in using a 1/2 piece of PVC pipe. Shipping was $10 and it arrived in two days.
tomjasz said:There have been changes in the case as well. From 5 screw to 7. Sorry no pictures just a description from a vendor.
Karius said:I advertised my pack to my supplier in China, and he sent me this picture. The suppliers have drawn arrow and written text in the picture. I see that the nut he points out, has a different placement of the holes than I have. I do not quite understand what he means by this picture. Language problems are a major issue. I write and speak bad English, and so does my provider too.
I'm currently quite confused.
Chewy: Did you have the opportunity to take a picture of your motor? Nice if you have the serial number of your motor too.
Regards
8Fun BBS-02 750W / 48V
Serial no 150303334
Chewy said:It won't let me post photos as they are too large.
My serial number starts with 1504 so I guess April 2015 manufacturing date ?
