scmountain
- Joined
- Feb 20, 2014
- Messages
- 2
I have bit off way more than I can chew, In my desperate struggle to figure this out, I stumbled by this site, and the knowledge base is amazing, problem is, it is a bit beyond my expertise. So please bare with me...
I am building a 12v system, The plan was to make a pack with A123 26650 M1's. The pack setup would be two, 4 cells in series (13.6v avg) wired in parallel. (4 single cells in series, two of those in parallel)
This pack would then be wired in parallel to a 12v 20ah AGM boat battery. (not sure what kind of controller i need for this if it is at all possible) The boat battery will be fine with the 13.6 volts as it is made to handle alternators cranking beyond 14.2v... I haven't found any info on people doing something like this, which has me scared that there might be a reason for it.
I have the A123's already (dewalt dc9360) and using these LiFePO4 batts would increase Amp hours by 25% for almost nothing in weight...I did save the BSM, but not sure how I could use it to help my pack as im not keeping the original voltage 36v.
and here is the juicy part.
I have a 6watt 12v solar panel hooked up to help reduce power drain. Having this many variables has really made my google quest quite difficult. (trying to up to solar wattage)
Any advice or places to look would be awesome. Sadly as 90% of internet article regarding the use of the M1's is for EV's which takes the voltage way outta my range haha.
the application if you are interested...
A portable cooler stereo! I am on my 3rd version now, trying to do a fine dance between weight of cooler w/o "refreshments" and play time of tunes. this is why the M1s would be so awesome if I could get it to work. I know I need some type of controller to shut the batts off before they deplete themselves beyond repair as the boat batt is deep cycle it can run till the stereo auto shuts off do to low voltage.
version1 of the cooler had 13watt solar and 50AH (optima yellow) that thing could blast any level for days, just weighed a million pounds!
Thanks in advance to any insight I recieve, this is my first foray into the battery world, real packs, not duracell duct tape packs from my youth
