And another update:
After extensive tests of the 16 S pack that had been accidentally discharged down to around .35 V per cell
(Turned out my controller had about a cup of water in it from a long, nearly horizontal rainstorm... water must have run down the wires and seeped through the silicone seal..., and I had left the master switch on, so there was a continuous three to seven watt draw for a few days after the storm, before I went to use the vehicle again.)
Anyway , all but three recovered enough to be usable. ranging from about 17.3 to 19.1 AH on the CBA, tested several times each from 25A to 10A. The three rejected ones were averaging 14. 16 & 16.5AH The swelling on most of the cases went down a bit with cycling, which was kind of a pleasant surprise.
I had another 14 of them sitting on a shelf (
fully charged, DOH!!!) for the last few years, never used, just the original CBA tests... I ran those through a similar CBA test program, and they were mostly equivalent in range (19.5AH to 17.5AH) to the ones that had been so abused.
Then I ordered five new ones from BatterySpace.. and tested them a few times on the CBA at 25 to 10A, They have made some significant improvements since I bought the original 30 batteries. The WORST of the new ones were about 1 AH more then the best of the old batch, and the best of them was about 3.5 AH better than the worst of the old ones on the original CBA tests., ranging from 21.118AH to 22.285AH @ 20 A draw.
Physically the cases have changed from the old ones. The new ones are about 1/8 inch taller than the old ones, and the plastic ridges are differently arranged. And instead of a screwed in vent caps like in the old ones, the new ones have a glued in cap.
I can supply the CBA test files if anyone is interested enough to want to look at them.
