I recently got a decent deal on a Bionx 350 SL that I intended to put on my Cannondale tandem. But as it turns out, the dropouts on this tandem are 145mm and the Bionx is designed for 135mm. Had it been a steel frame, I could probably stretch each rear triangle 5mm quite easily, but this doesn't seem a good idea with aluminum. I could perhaps flex it about 2,5 + 2,5 mm and then add a 5 mm spacer, but I would then need to dish the wheel further, and the cassette would be offset by 5mm relative to the derailleur.
As far as I understand, the the (anti rotation) axle collar comes off (with a puller tool) - does Bionx provide a longer axle collar for 135+ dropouts? Or is there any other way to install a Bionx on a wide aluminum frame? I really can't seem to find a sollution on google. I've seen people install on wider than 135mm dropouts but I'm beginning to doubt if anyone did it on an aluminium frame.
Erik
Erik
