mattjrogers
- Joined
- Apr 15, 2017
- Messages
- 10
Hello, first post here, been lurking awhile.
So anyone ever checked the voltages at their BMS sense wires and found one that fluctuated back and forth between two voltages every second? That is my issue and it is shutting down my battery.
I have a BMS and battery issue that I could use some help with.
Generic LifePo4 battery pack 48v 40AH. 16s aluminum case prismatic cells. All cells individually test to 3.3v. The pack has been sitting for 2 months or so, no real change in cell voltages over that time. I am in the process of splitting the pack to mount on either side of my bike (Big Dummy). The battery was working fin before I took it apart and not after hooking everything back together as a split pack, I am getting some weird voltage readings.
I am posting a link to the pictures in case I don't get the image upload correct. https://goo.gl/photos/pfhnH8H4yJdck3WY9
First picture of the split pack. I plan on redoing the BMS sense wires at some point, they are just crappy soldered to some other wires at this point - how they arrived from China. But I checked each wire connection and they are all solid and have the correct voltage and continuity, except one - problem described below.
The next picture shows the BMS. There is an XT60 with the black negative from the other battery pack and a red wire which is the serial connecting wire between the two battery packs. I get exactly half the pack voltage from these wires when checking them against each other (26.2v) at this time (pack is partially charged). I also get full voltage between B- and the Positive battery output 52-53v. I get 52v from B- to one of the Mosfet terminals.
Here is where it gets weird. I hooked the battery up to the charger to fully charge it and when I took the charger off, I noticed that my Turnigy watt meter went dead. I checked the voltage manually at the battery output (XT90) and first found a voltage of 13.1v. I checked a lot of connections, tightened some, checked again and eventually got to the point where I was getting 1.7v. So I checked the sense wires and their voltages to see if one was dead and the BMS was shutting down the battery. I get normal voltages as I go down the wires 3.3v-6.6v-9.9v-etc until the last wire, when checked carefully it changes voltage back and forth from 46.1v to 52.1v at a rate of every second, constant pattern.
I checked the board for burnt connections or components and don't see anything other than some left over sticky foam that was protecting the board. I don't exactly know what components the two rows of rectangular black boxes are that sit above the rows of resistors coming from the sense wires, but the one that I am dealing with has varying voltages across its terminals. One terminal switches back and forth from 46-51v, the other stays constant at 52v. The voltage at the top of the top row of components is 13.1v - the number that I was getting at the output at one point.
I am very mechanically inclined, but let electronic technology get a head of me. I would like to learn how to diagnose and fix this issue, so please give me some tips and hints of what to check. I will try my hand at replacing a component, if needs be.
Just let me know what info I am missing to help and I will get it right over to you.
Thanks,
Matt
Thanks,
Matt
