tifalou said:Hi, I have tested the 12 mosfet controller with my Puma motor. It can only reach 15 mph on no load, whereas it does 27 with its standard controller. Do you think that the 12 mosfet controller has a feature that limits the current in order to comply with the european speed limit ? If so, how can I release it ?
Another question : The two white wires have connections made for being connected together, so I did it. It made the wheel spin at about 10 mph, whenever the throttle is off. So what is their real use ?
Thank you.
Hyena said:Mine seems to have different wiring to the earlier ones - there's no white wires on mine but there is a brown one that's connected the same. I tried unplugging it and it made no difference so I've left it connected for now. I also have a single purple and a single white with green tracer that I don't know the function of. There's also a black + orange w/green tracer but I've worked out by shorting that it's the brakes. I'm not sure if it's regen or just plug braking as my watt meter doesn't measure current going backwards. The automatic cruise doesn't seem to work either. Maybe that's the purpose of the joined brown wire ?
Russell said:The wires are identified in the first post.
The grey loop is the auto cruise control, when it is cut it is disabled, when a momentary switch is added you can turn on cruise with a push of the button instead of waiting 8 seconds for auto-cruise to start.
Info on the controllers can also be found here;
http://www.ecitypower.com/index.php?option=com_weblinks&view=category&id=19:ccd&Itemid=93
I also cover the hook-up and function of the otherwise identical 9-FET version here;
http://endless-sphere.com/forums/viewtopic.php?f=4&t=13659&start=0
-R
tifalou said:I've got a 350W and a 500W controllers from bmsbattery and here are my observations :
- They can work sensorless with my Puma and my GM (I fried some hall sensors) despite some vibrations and noise at startup.
- I drained one battery, because neither the bms nor the controller cut off. Need to keep an eye on the wattmeter ;
- no mean to connect my double-wired brakes with cut-off sensor.
- While Ecitypower told a customer on ebay that the controller has no speed limit, both mine seem to have a speed limit :
when I reach 20 mph, the power suddenly falls from about 700W to 300W, and then rise again when the speed has decreased. It can not be a current limit, because on hills it can reach 1100W on 36V.
I don't think that I can improve this, so now I guess I have to look for a better choice. Any idea of a good 36-48V 30A universal controller ?
tifalou said:You seem to be right Russell, the curves fall suddenly above 20 mph. I knew that, but with other controllers, when the speed reaches its peak, power and speed stay constant, so the ride is always smooth.
In the present case, when the power falls, you can't sustain your speed, it falls, then the power comes back until 20 mph, then cut again, and so on... unless you keep it just under the limit. Not comfy.
I'd appreciate to find a smoother sensorless controller, which would also have 2 wires for the brakes.
