Bmsbattery S12SN 72V 40A sine controller worth trying?
After a lot of time fooling around on the ebikes.ca simulator and a lot of time reading here I'll be going to 20s on my 26" rear 2809 9C build soon, I have my 18650 battery build parts ordered and am about to order the cells. I've been dithering for a while over which controller to get, I like the idea of a sine controller for lower noise but there seems to be zero experience on the net with this particular unit. I really wanted to use the Phaserunner FOC controller but with new batteries too it's going to be out of my price range and it's backordered until next year anyway apparently. I may still go with the Phaserunner in the spring but I need something to get me by in the meantime since I don't have a 72V controller and this looks like a fairly low cost option that I can move to another bike later when I get my main ride all done.
I wouldn't mind using the PAS on this so which bmsbattery PAS sensor would be best, the one with the most magnets?
Any input is appreciated.
Controller..
https://bmsbattery.com/ebike-kit/73...imulation-sine-wave-controller-ebike-kit.html
LCD for the controller.
https://bmsbattery.com/ebike-kit/737-72v-s-lcd3-lcd-meter-for-s-series-controlers-ebike-kit.html
You can use any PAS. You hardly notice the difference, but it is a case of the more magnets, the better.
You'll need the wheel-speed sensor too.
If you want to pedal, these controllers are really good. There's little advantage if you only want a throttle.
I'd forgotten about the wheel speed sensor thing, I read that a while back but it had slipped my mind, thanks.
In your experience are the bmsbattery sine controllers less noisy than an equivalent trapezoidal converter?
