BVH
- Joined
- Mar 26, 2009
- Messages
- 411
I've been tweaking my new E-Commencal Meta for about a week since I got it. I haven't ridden it yet because I want to beef up the electrical conductors and add a handlebar mounted, contactor activiating On/Off/Kill switch. Hopefully, those parts will arrive today. In the mean time, I've been concerned about riding it without a torque arm. Maybe I'm worring for no reason but so be it. With a very large, unusual shaped swing arm leg, I've been thinking about how to come up with a nice-looking bracket to attach a commercially available arm. Then one day, as I was looking at the dropouts, a simple idea hit me. Why not use the aluminum dropout insert bolt hole. The inserts are held in by a chainring type nut and bolt. I was going to figure out a replacement bolt but its a very fine thread and preliminary searches yielded no 8m, 8.5 threads per inch bolts. As I'm staring at the setup, it suddenly hits me....why not just stick a bolt through the center of the chainring bolt? Here's the result.
The thickness of the tab is a full 3/16" so it's a pretty beefy Torque Tab. Can anyone shoot holes in this setup? The only thoughts that crossed my mind are the size of the bolt - 10/24 - is it strong enough and Is there a possibility that the torque will tear out or elongate the factory insert chainring type bolt or swingarm area and finally, should I have another one on the other side? The other side will have the standard tanged washer that allows about 10 to 15 degrees of turn before it contacts the aluminum dropout.
A thought after looking at these pics. What if I drilled the back of the tab and aluminum dropout insert and bolted them together? That would essentially strengthen the "dropout" by closing it.
EDIT: Inserts are Aluminum, not steel. No room to drill. Scratch that idea.
