bobc
I thought I should start a thread about this project.
The idea is to make the cheapest and simplest possible legal ebike conversion.
I want to cover the whole thing including electronics.
So here is a picture of the mechanical assembly: it is intended to fit onto the seat tube inside the rear triangle.
The separate drive roller is smaller diameter than the outrunner rotor in order to run efficiently at legal speeds.
The motor is a cheap outrunner from hobbyking or elsewhere. I've used a propdrive 50/60 270kV (from hobbyking $35)
The Controller is a 60A RC ESC with BEC 6s capable. I've bought a "mystery" one (£10.50 off ebay)
Initially I will mount a single 6s 5Ah lipoly battery - this should be good for 7 miles or so on the flat with no pedalling (15.5mph). Cost about £40.
Custom parts are
1) drive roller with taper lock fixing to motor shaft
2) swinging motor mount frame, laser cut stainless steel
3) seatpost clamp parts, fashioned from 10mm Ally sheet
I'll post drawings for the bits as I do 'em, so if it turns out OK anyone can copy it.
Custom parts are
