After two minutes, the first officer reported a “flight control problem” to air traffic control. The captain asked the first officer to check the quick reference handbook that contained checklists for abnormal events, the first source told Reuters.
For the next nine minutes, “the jet warned pilots it was in a stall and pushed the nose down in response”, according to the report.
The captain tried to get the plane to climb upwards, but the jet’s computer system kept pushing the nose down. It appeared the system was incorrectly sensing a stall.
“They didn’t seem to know the trim was moving down,” the third source told Reuters.
“They thought only about airspeed and altitude. That was the only thing they talked about.”
The pilots — the captain, 31, and the first officer, 41 — remained calm for most of the flight.
It was right before the crash the captain asked the first officer to check the manual as he struggled to control the plane..
Yeah, that's been out for a few months now. The DFDR data shows exactly what happened when. The first MCAS down trim happens 1:40 into the flight, right after they retract the flaps. (Flaps-down disables the system.) As the system adds more and more nose-down trim eventually it overpowers the pilot.Hillhater said:Lionair''s flight data released..It looks to me like the plane first tried to nose dive within 90 secs of take off !
Shut down both pitch trim motors.Punx0r said:So what was the planned contingency in the system for a faulty AoA sensor?
Punx0r said:...It's making me think there must be more to this tale, that it can't be this disastrously simple?
MJSfoto1956 said:One possible simple reason: the Trump administration gave an implicit green light to anyone who was concerned about those "pesky" regulations -- as they made it patently clear from day one that there would be limited-to-no-oversight by any Federal department going forward. And that is no exaggeration. This is what "success" looks like as long as these clowns are in office.
And one of those airlines added four more after a separate fatal crash in Indonesia took 189 lives in October.
Air Canada has 24 Boeing 737 MAX 8s, WestJet Airlines Ltd. had 13 and Sunwing Airlines flies four, according to Transport Canada’s civil aircraft register.
WestJet confirmed that it has 13 Boeing 737 MAX planes in its fleet — and that’s four more than it had in November when a Lion Air flight crashed in the Java Sea.
Those planes represent just over 10 per cent of the Boeing 737s that it flies in total.
Asked why it added more of those planes following such a devastating crash, WestJet said it has an order for “50 MAX aircraft and have ongoing deliveries.”
Good question. I don't know of a physical indicator that illuminates - and since it's a normal part of most flights, a warning or caution indication (via a master caution indication) would not make sense. However:Punx0r said:Thanks for explaining that, Bill. So the pilot would detect a change in attitude of the plane, automatically realise the problem can only (or most likely) be with the pitch trim system and kill power to it with an easily accessible switch? Is there any indicator that pitch trim is currently applied to assist the pilot in diagnosing the problem?
Yep. From the DFDR data, the pilots did everything that Boeing suggested - and still couldn't control the aircraft. Not throttling back was definitely an error, but it's also understandable - airspeed and altitude are somewhat interchangeable, and there's a natural desire to not slow down needlessly when you are at low altitudes.Punx0r said:Well the first report is out on the Ethopian crash: http://www.ecaa.gov.et/documents/20435/0/Preliminary+Report+B737-800MAX+%2C%28ET-AVJ%29.pdf/4c65422d-5e4f-4689-9c58-d7af1ee17f3e
Some reporters are claiming the pilots followed all the correct procedures provided by Boeing but were unable to control the aircraft, with Boeing now admiting there is a fault with the MCAS system: https://www.bbc.co.uk/news/business-47812225
Reuters claim the problem originated with a bird strike just after takeoff damaging the Angle of Attach sensor, causing the MCAS fault and the pilots were ultimately unable to control the plane due to their own mistake of having kept the engines at full throttle since takeoff: https://uk.reuters.com/article/uk-ethiopia-airplane-reconstruction-insi/how-excess-speed-hasty-commands-and-flawed-software-doomed-an-ethiopian-airlines-737-max-idUKKCN1RH0FG
