gibrocksonne
10 µW
- Joined
- Dec 14, 2012
- Messages
- 5
Hello,
Since 3 years, I'm using a MG310_Std on a MTB bike with semi-slick 26" tires to go to work : 11km/day, (7 miles) bike lane on urban area, absolutely flat. I have a 36V battery, biker+bike weight is 75kg (165lb). Depending on the wind and battery voltage, I'm cycling at 29-36km/h (18-22mph).
My battery is a 36V/11Ah with 5P-10S Samsung INR18650-29E, assembled by me, 5 years ago. It has something like 10000km now. Capacity have dropped a little bit, probably -20%.
My motor is a Bafang MG-310-std. Is is really light and I really love it.
I always take care about the motor and I've limited the power to 400W to avoid high torque and high battery current (and bad efficiency).
I'm using the pedals, I think I give something like 100-160W of power at all speeds (48-11 max bracket, 2x9 config).
In the next months, I may move further. I will have to do 30km/day (19 miles) : 10% urban and 90% on a dedicated lane for bikes, with almost nobody, outside the city. Still almost flat (0.4% avg / 1% max slope). I would like to boost my speed to 35-40km/h (22-25mph).
I'm looking for minimal change on the bike: ideally I would like to change only the motor (and eventually bracket). Next time I will re-build my battery, I may change from 5P-10S (voltage range 30-42V) to 4P-12S (36-49V, -20% capacity), if needed.
I looking for a good candidate to replace the motor :
- The same motor in fastest version (MG310-fast)
- Bafang SX2 Fast
- Q128C (328RPM version)
- Any other option you'll give me :wink:
Since I will spent 90% of my time at 38-40km/h (290-310RPM, 26"), I'm looking for a motor that will have its best efficiency at this speed. I'm also looking for a very good reliability and maybe bafang motors are better, but I may be wrong.
On the ebikes.ca site, they said the fast version of SX2 is intended for 20" wheel. It may imply that this motor don't have enough torque to keep its nominal speed with 26" wheel (or not at a good efficiency). The MG310-fast is ligher, I'm not sure it will have more torque.
Please fill free to give any advice or share your experience
Many thanks
- Bafang SX2 Fast
Many thanks
