I know everyone says not to split the packs but as I needed a very custom shape and 48V I had no choice. So I did this:
Opened the packs and cut open the red plastic. No need for a dremel, a sharp knife removes the plastic in 10 seconds.
Separated the cells in packs of one or two by cutting the tabs. I bent the tabs over and added solder.
I then glued the cells together with a LOT of hot glue. 12 gauge cable was tinned and soldered to the pre-tinned tabs.
I the added a lot of hot glue on top of the battery (well, both sides) as well. The pack is very solid and with almost no chance of anything shorting out, even in a wipeout. But it is also close to impossibly to swap out a cell....
Around the pack I added bubble wrap and duct tape, and a 60A fuse from one of the fatpacks.
The resulting pack is 48.1V and ~11Ah, 13s9p configuration. 54.6V hot of the charger (will adjust this down to 53.3V).
I have ordered a custom in-frame bag from Epic design, awaiting this I mounted the battery with duct tape for the time being. The bike is fitted with the Ezee kit from ebikes.ca, and Cycle Analyst.
Speed on the flats with NO pedaling: 25mph(!)
Moderate effort pedalling: approaching 30mph.
The pack never went below 50V. I'm very happy with the results!
So, one can quite easily split these packs if one needs to for whatever reason. I used two evenings to build the pack. The pack is just under 10 inches tall, 12 inches long and a little over 3 inches wide. Weight 12 lbs, complete bike 45 lbs.
I knwow it's not a "clean looking" battery build, but it works. Quick and dirty
Pictures:
BTW: This is a crap seat, not the one I normally use.
