Eric G
Hello...
I've got a Crystalyte brushed rear hub motor (600 watt) with 25 amp controller running 36 volts sla in a 20 inch wheel folding bike.It's served me very well up until now with 7000 kilometers on the odometer.
The other week while riding I've noticed when I apply throttle it stutters and growls as I speed up.The stuttering and growling disappear as I approach full speed of 32km/hr.If I get off the bike and lift the back wheel and give throttle with no load it ramps up to full speed perfectly with no growling or stuttering what so ever.
The bearings are fine,with no grinding noise.When I hook up my watts up meter between the batteries and controller raised the back wheel applied full throttle,it reads .7 amps which I think is okay.I disconnected the motor attached the motor leads to a voltmeter and it measured 2 to 4 volts spinning the wheel,I don't think any windings are shorted.
I've also disconnected the motor from the controller and hooked up the voltmeter to the controller out side and it measures 0 to 39 volts as I turn the throttle so the controller and throttle seem okay.
I've triple checked all my connections and all seems fine.
Could this be the brushes starting to fail?If it is why does it run perfectly when I'm up to speed,would it not growl and stutter all along or get worse as I speed up?
Perhaps I've forgotten something else to check.This ride is my sole means of transportation and it's important that I get it sorted.Some guidance with this would be greatly appreciated.
Thanks
Eric G
Thanks
Eric G
