Hi Texaspyro, hoping that you monitor this thread and that it's better to ask the question in public:,
I just started working on some arduino projects, which are very simple to use, cheap, microprocessor boards with a C based, but somewhat simplified, environment. I was thinking it would be relatively easy for me to build a program that turned on a number of transistors with a certain length of pulse.
I don't have much experience with fets, and I don't know if it'll be enough to simply apply the voltage to their gates for X milliseconds, then turn off. But if that is enough, and if it's reasonable to turn on a bunch of mosfets with a few different pins simultaneously, then I could think about making something slightly more useful than just a thyristor switch.
And, if you think this might be something that could work, how would I go about learning about what sort of pulses might help me? I now that you want a micro pulse to burn off the oils before a more serious pulse, but I don't know much else. I'm also looking at contenders for the fet, and found a bunch of creatures that are rated for 100-300A and not too expensive, but I'd look more thoroughly to compare the resistances etc of everything.
So, because I realize I am just getting into this, I'm mostly looking into whether this would even be possible to do. I'm also wondering if there's much sense in it, obviously your setup is much more sophisticated and the code is more complicated, but I'm curious as to how much I might be able to benefit by using a $20 microprocessor board and $20 of FETs. Probably, I'm just going to gain some resistance in the whole situation >.<.
