ev tocak said:
Hi Jason , if this buck converter u pasted is based on lm317 ...it wont work dont bother with it .U need a led driver with that + step down .
Best of luck
Not sure what you mean by based on lm317?
I know the 100W led I bought needs Forward Voltage between 30-35Vdc and a current 3000 - 32000mA
Here are the specs on the buck converter
-input: 4.5-63V (
I'm going to have 36V ping, 41V charged )
-output: 3-60V (
I would tune this down to 30V )
-D-value of voltage: at least 3V between input and output voltage (
In the morning with a fully charged battery this should not be an issue )
-current: Max current=3/(input voltage-output voltage)
-load regulation: ±1%
-voltage regulation:±0.5%
-Dynamic response speed:5% 200uS
-temperature: industry class (-40℃ to +85℃)
from what I saw on one site (ill see if i can find it again) it said all i would need is a buck converter with low ripple as the led driver.
