MrDude_1
SO long story short, chain jumped, wrapped on the gear bolts of the rear sprocket and yanked on the motor shaft with enough force to bend it.. bend the 14mm stainless steel shaft.
So now I need a new 14mm shaft. I am having issues finding non-magnetic steel rod 14mm od. I can find steel rod though.
Can I use steel inside, or will there be eddy current losses and heating from it?
