I have this junk toaster oven (door opens type) that I want to use the heating elements for a heater powered by my 25-45 volt 4 amp solar panel. I want to make a direct connection with just a diode, fuse, and on/off, and maybe a small fan to give it some air flow. Will this work? obviously I will not be running anywhere near the rating of the elements (8amps or higher at 120vac). I just want to convert my solar panel power into heat inside the house in the lowest cost (free) manner. Yes I know PV for heat is stupid inefficient, but at the time I am not willing to invest more money into inverters and grid tying to use the PV as electric power.
So for now, in the winter, I can at least get some heat from it.
I know I can just use 100w incadescent light bulbs, but I would need a lot in parallel, as each one might draw only .3a at 40v
Will this work, or short the panel? Or something else bad?
