chisixer6
I am still a little confused on charging of packs. I have 2 6s packs in series for my 36v motor.
I have a icharge 2008 (20a 8s) powered by meanwell 600watts 24v.
I want charge say two 6 cell 5a packs that was in series;
I can charge one at a time @ 5 amps 1c , or 10 amps 2c
or I can charge both 6 cells at same time, if I take the series cable off and use my paraboard hooking up the 2 packs.
Is this correct?
I can charge both at 5 amps each @ 1c or 10 amps each @2c. Is this correct?
If I charge 8 6s packs on a paraboard, but max amps will be limited to 20 amps totalor 2.5 amps each, is this correct?
thanks for you time..... Jerry
Is this correct?
