Its not an error, just the default settings in NITRO KIT is pedal assist mode. If you plug in the twist throttle, it will only work , if you install PAS sensor, and pedalling.
The P4 parameter (in advanced configuration) must be set to 0, for always throttle response mode.
And the assist level must be set to 1-5 (not 0).
(This Ciclotek NITRO LCD5 KIT is maybe MXUS XF40 30H motor + KT LCD1 controller.)
[youtube]pfshHNWMtSg[/youtube]
