It has been some time since I contributed, but I've been pretty busy working on my bike. Here are the results:
The battery pack will consist of two blocks of 6 4s packs on each side. I've used silicone between the packs, two aluminum angles on top and bottom and fiberglass reinforced tape to hold it all together:
My portable charger will be placed on top of the pack. It will also contain an Arduino, which will be used both for controlling the charging and as a CA and the BMS. To save money I got 3 x 8s BMS from GGoodrum (I'll have 2s 2p 4s-packs connected to each BMS board).
The components are just placed to see how much space I need:
Making the box was a nightmare and you are much better off buying one.
I got a used 9C 9x7 from GCinDC. I test drove the 6x10 and the top speed even with 24s wasn't fast enough.
The halls are a simple matter:
Surprisingly the resistance between the windings and the metal part is just 1.2Kohm (same for all three phases).
On the other side you can see the phase wires and buried under the windings is a temp sensor (LM35DZ), which uses the same 5V as the halls and therefore only needs one extra signal cable going into the motor:
For those who are not using an Arduino or similar I strongly suggest this temperature/voltage alarm:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9744
$7.80, very flexible, easy to use. If you want to use the hall wire 5V to supply the sensor, you will need to use common ground and pull one signal cable through the axle.
Lacing a wheel is fun if you know you have the right size spokes - I wasn't sure
Lessons learned:
- think twice before you do anything
- before making an e-bike talk to someone, who already has one
- right tools make your life easy
- J-B weld is awesome
- silicone wires rule
- my wife hates when I solder stuff in the living-room
Coming up next:
- insulating varnish treatment for the motor
- Hua Tong controller should arrive in three days
- maybe first test ride next weekend
