m52 power!
- Joined
- Nov 27, 2013
- Messages
- 56
Is there any general temperature range to compare the outside case of the motor and what the internal should approximately be?
Reason being is I am seeing higher temps reported on my CA than I was expecting. I am running a crystalyte 4065 on 72V LiFe and max 50A. Continuous watts at speed is around 2300. After 10 minutes CA is reporting 100C. After 20 minutes CA is reporting 115C. I have my CA set to start limiting at 100C and off at 120C.
I took some measurements at the end of my ride. The max temp on the case was 62C, while CA reported 110C. Does this sound like a normal temperature differential?
Is there any other way to confirm it is reporting the correct temperature?
