footloose
Would appreciate advice of others with expertise in small motor builds.
I’m considering a build using either a Q100 or Bafang SWXU.
Would be front wheel drive, in an old Raleigh 20 folder (extensively modified, it rides very well, a favorite bike).
Don’t need brute strength or rocket speed in this build.
Value lower-weight over higher-performance.
Ride profile: 12 mile round trip, 80% flat, but with one significant (~8%, ~1mile) hill.
Not ideal, but can recharge at office if necessary.
15-18MPH top end fine.
Lots of stops and starts. Longest straight, flat run w/o stops <1 mile.
Don’t mind pedaling.
Plus need to carry the bike up a couple of steps into train.
I’d like to use an existing battery system I already have, currently powers Commuter Booster setup.
It is a homemade 6S3P A123 LiFePO pack.
Built of 3 discrete 6S1P modules, could be rewired into 18S1P using all three, or 12S1P by using only 2 of the packs.
In perfect world, I'd keep existing battery config so I could swap it between bikes.
For purposes of consideration, here are the basic parameters of each possible battery config:
6S3P (current config):
VMAX: 22.8V
VNominal: 19.8V
VMin: 15V (my choice… could safely go down to 9.6V in theory... but below 15V it drops quickly)
Ah: 6.9
12S1P:
VMAX: 45.6V
VNominal: 39.6V
VMin: 30V
Ah: 2.3
18S1P:
VMAX: 68.4V
VNominal: 59.4V
VMin: 45V
Ah: 2.3
So here is my quandary: What is the ideal motor / controller / battery config?
For example:
Q100 24V 328 RPM motor, under-volted using 6S3P battery, but slightly over-amped using a 24V controller with “partially soldered shunt”?
Q100 36V 201 RPM motor, slightly over-volted using 12S1P battery, with a standard 36V 9FET controller?
SWXU 36V 201 RPM Motor, way over-volted using 18S1P battery, with a 48V 9FET controller?
Give up on re-purposing existing battery pack?
Other?
Lots of possibilities. Advice appreciated!
VMAX: 22.8V
VNominal: 19.8V
Ah: 6.9
12S1P:
VMAX: 45.6V
VNominal: 39.6V
VMin: 30V
Ah: 2.3
18S1P:
VMAX: 68.4V
VNominal: 59.4V
VMin: 45V
Ah: 2.3
For example:
Other?
