appleseed123
1 W
Ok, so I got a Lyen sensorless controller for my bike. My motor is a HS3540 with 3 12v SLA in series
The bike works awesomely. One thing thou that is weird, when i disconnect the ground to the battery the controller shuts off (all good, i use a key/switch on the ground wire for ignition), but if i go to bike again with the battery still disconnected the controller starts back up again from the electricity from the motor.
It only starts up again at about 10km/h , and below that it trys to turn on and off over and over.
I am not on the brake (regen works thou), and if i try to use regen nothing happens (with the battery disconnected).
When i am at a stop, the CA says -3 watts so maybe that has something to do about it?
Any idea? I dont want to wear out the controller by biking with using the battery.
