Skedgy Sky
Hi all! I decided on rebuilding my 4110 6FET into a high voltage backup controller.
Necessary changes I made for HV operation
R12 is 600 ohms (2x programmed regen multiplier)
R01 is 500 ohms.
4115 FETs added.
High voltage caps added
It worked at 90V, but 126V it took out the Lm317 which I replaced.. then accidntally killed the 2nd one (d'oh!!)
What other changes are required to make the controller operational at high voltage (I'm sure it's just something on the resistor network)? Thank you.
R01 is 500 ohms.
4115 FETs added.
