veloman said:
I didn't glue the heatsinks to my Mac yet. I tried it on an Evt scooter hub (much bigger). The thermal adhesive works great and I've yet to lose a heatsink.
I say, give it a shot. Probably won't help nearly as much as venting, but should help some. Double that surface area!
I already ordered the thermal adhesive....and when it arrives, I am gonna do your modification. I like your idea because its not messy using oil, doesnt require drilling holes in the hub that can allow dirt/ water to get in , and your mod looks kinda cool. I am confident that it would have to help keep the hub motor cooler...just not sure by how much nor am I sure if cutting all the aluminum fins the exact same length provides the best cooling results
Im thinking of trying your mod...but instead of having all the fins with the same length vertical sides , make them so each fin on the back of each piece is 1" taller then its front fin...that way when the wheel is spinning , it may result in more air circulating around the hub/ fin grouping.
I also may place some aluminum fins on the left and right outside portion of the hub , where the magnets and coils are near the outer edges . I may cut them to be like a sideways V shape ,,like this :
and have them go circular around the outer edges of the hub,,,,maybe offset them, for better air circulation ? like this ?
1- 2 -3-4 -5 - 6-7-8-9-10
maybe do that pattern and for every even numbered fin { 2-4-6-8-..etc } have it glued about 1/2" higher on the hub , then the fin in front of it , so its V opening can draw in more air.
