footloose
Need advice, please.
Is what I'm proposing reasonable, or is it not?
Currently I have 3 hand-built battery packs, each consisting of 6 A123 cells in series yielding a nominal 19.8V / 2.3Ah.
They are then connected in parallel, creating a larger pack that yields 19.8V / 6.9Ah (6s3p config)
I use it to drive one of Adrian's Commuter Booster setups... works great.
I'd like to repurpose the packs for another build, but in a way that allows me to swap them back into Commuter Booster config easily.
Design goal of the new build is 49.5V / 2.3Ah.
Will be a very short range setup, but also very light if it works.
Could this be as simple as adding new + leads between cells 5 & 6 on each pack?
Voltage on the new leads would be 16.5V. (5s1p config)
Then connect the modified packs in series, yielding 49.5V. (15s1p config)
Effectively, in the new configuration cell #6 of each pack would become "invisible" to the circuit... but would remain available for use if I want to swap config back to original setup. If I want the higher voltage then use the original + lead... If I want the lower voltage, then use the new + lead.
Assuming this works... any issue with charging the 5s config simply by using the new lead, charging the 6s config simply by selecting the old lead?
If sensible idea, cool. If bad idea, I'll stop being a cheapskate just buy a new battery for new build :wink:
