scriewy
hey pps, how YOU! doing.
ok let me give you the layout.
at this point i dont know anymore if this info is relevant, but i'l mention it just in case.
crime scene: i finaly got my 405 clyte after months of waiting !
laid it on my bed, felt it, was nice and smooth, hooked all the wires 1 dewalt 28v and 24-72 40 clyte, twisted the throttle a bit the motor budged, i got happy, disconnected wires took the motor to set it on the rear axle.
connected wires back, controller was on the floor, throttled slow it started rotating, so quiet that only when i WOT i heard mechanical whoooosh that probably came from the bearings, played around 1 min and noticed a nut on the mini xlr plug, turned power off disconnected xlr and twisted the nut a bit, xlr's pin head got loose and i twisted it 1cm back and forth out of curiosity, connected it back throttled and sudenly the motor started making click click sound and shuddering.
im like WTF ?!
i tried WOT and it started vibrating violently.
stuff i figured out back then, there was the normal cogging without any power when i rotated by hand, a bit of extra cogging when power was ON, after it got messed there was much more cogging with power ON, when i hand rotated the motor in it's intendent direction i felt like it was heating a wall/barrier inside, i figured it's magnetic cos happened only with power ON, the faster i rotated the motor the stronger i felt every hit.
there's like magnetic alignments and blind spots between them, there are many normal resistence spots but fewer of this barriers across the radius.
at WOT motor looks like totaly out of sync and just starts vibrating violently.
didnt saw any sparks fly or smoke while i disconnected the XLR and reconnected it, didnt short circuit anything.
this happened on thursday.
thought: shit after 75% throttle motor goes crazy so how will i run it over 28v.
started searching for stutter\ing shudder/ing vibration\ing motor, yesterday finished reading 100s of pages from 30+ threads, tried to hook 2 dewalts 53v, motor passed the old 75% throttles RPMs but started vibration after the new 75% throttle RPM so i figured it's something to do with signals not mechanical like 1 case with loose magnets.
checked controllers phase and pos neg wires with DMM at 2Mo (while controller is off, or should it be ON just not hooked to battery ?) all showed 0.348 0.350, then learned how to check hall sensors he he , xlr started giving me the stink eye i said i'l bust a cap in your pin ! took from some old PSU single hitec terminals and cut with hot knife some single terminals that hook to pc motherboards (tamya ?) they fit snugly XLR pins, striped shrink tubing, juiced 5v battery from behind XLR's head and got this
y - 0 - 0.58
G - 0.4 - 0.7
B - 0 - 1
do i have to use 1k resistor ? i didnt.
so the green sensors looks dead, or semi broke ?
baterry sags at WOT no load to 26v from 26.6v, current draw at WOT 3amp, which looks pretty a lot for no load run.
checked XLR wires soldered to the pins seem fine and hold good, then idea came to play with phase combinations see how it'l spin backwords if at all, but before that i hooked eligators in correct order dont remember what for, suddenly there was less resistance then when the andersons are connected directly, the clicking almost went away but still there, and at WOT no violent vibrations any more, just clicking left, top no load speed 20mph (looks slow for 26v ?)
at this point i'm confused, i plan to splice both sides of phase wires motor and cont and connect aligators from behind as it seems something weird with andersons on the phases when they connected directly, but how the motor spins better when i connect aligators in same order through the andersons, i'm only extending wire between the andersons and if they are messed up how can an extention wire correct the mess if it's connected between the messed terminals ?
if i were to bypass the messed terminals by splicing into the wires behind andersons, that's understandble.
so i dont know if to cut the andersons or to open the motor, would a motor even run pretty smooth with 1 sensors dead ?
i can make a video of it all, will it help ?
thanks a LOT !
im like WTF ?!
y - 0 - 0.58
G - 0.4 - 0.7
B - 0 - 1
thanks a LOT !
